Tractor Talk Discussion Forum
Holes in hood
Jack Boggs
10-22-2006 08:00:15
I have a 1951 MH 44 Std.Any one know what the three small holes in the left side of the hood were used for. I have seen these holes on other models of MH's also. Thanks, Jack
msb
10-22-2006 14:28:36
 Re: Holes in hood in reply to Jack Boggs, 10-22-2006 08:00:15
Just a guess: maybe brackets for headlights?
If you want to weld them shut,just hold a penny behind the hole and use a wire feed welder to fill the holes.The weld will not stick to the copper (coated) penny.
Bus Driver
10-22-2006 10:10:47
Are they close to the generator or something else requiring manual oiling?
Jack Boggs
10-22-2006 12:34:00
 Re: Holes in hood in reply to Bus Driver, 10-22-2006 10:10:47
No. They are on the side of the hood, above the starter. I looked at a 44 Special the other day and it had three flat bars about a foot long bolted the these holes. The came out at about a 45 degree angle and they were connected on the ends with flat bar forming a triangle. I ask the owner what this was for and he didn't know. I have a 33 and a 30 and they have these holes also.
massey333
10-22-2006 13:15:47
 Re: Holes in hood in reply to Jack Boggs, 10-22-2006 12:34:00
There are no holes in a Masey hood other than Rad.EX.Air Cleaner and the Holes for the Hood Mounting on the Rad.Suport and THE Rear mounting (Tie Down Brackets)at rear of hood.Do You have the Flat straps with a Bolt Welded to them on Each Side of the rear of the Hood?????They are held on with THREE Rivets each.
