Tractor Talk Discussion Forum
O.T. Cleaning Window Glass
Paul Hodgson
10-22-2006 15:13:44
Any suggestions to clean shop window glass coated with welding smoke, rust grinding dust, paint overspray and all other materials generated by a handyman restoration shop
JayWalt
10-23-2006 05:43:49
 Re: O.T. Cleaning Window Glass in reply to Paul Hodgson, 10-22-2006 15:13:44
I would be sure to rinse, brush off with a soft brush, the metal debris. If you just go at it with a rag and cleaner, you can scratch the glass up longterm.
The welding can pit the glass and ruin it. My friend does ALOT of body work and goes through alot of cardboard to tape up the windows, because welding can ruin them in a heartbeat. Why are you welding so close to a window?
dr.sportster
10-22-2006 19:26:35
Cleaned about a million windows in the Marines with vinegar water and newspaper.Still use it to this day cause its cheap and it works.
old
10-22-2006 17:31:42
Ol-cheif has it right on vinagar and newspaper work real well.
Ol Chief
10-22-2006 16:46:34
Vinegar and newspaper.No rags.
Shovelman
10-22-2006 16:30:45
Here's an old bodyman's trick: Find Bon Ami in bar (cake) form. Use a damp cloth, rub it into the bar and then apply it to the glass in a circular motion. After it dries, buff with a clean, dry cloth.
It will remove all kinds of grime, including paint overspray.
Good luck,
Scott
glennster
10-22-2006 15:48:57
try a product made by castrol called super clean. most auto parts stores carry it. it will dissolve most crud, you may need to scrub it a little with 4-0 steel wool, then use a glass cleaner after .
Leon R
10-22-2006 20:28:48
 Re: O.T. Cleaning Window Glass in reply to glennster, 10-22-2006 15:48:57
use a razor scraper to clean it off first then use the vinegar and newpaper to clean it up.
