Tractor Talk Discussion Forum
montana tractor
dgr
10-23-2006 13:19:03
good news bad news any info on 4540 45hp montana,also tractor insurance,thank you
Chad Franke
10-24-2006 06:13:21
 Re: montana tractor in reply to dgr, 10-23-2006 13:19:03
Won't get much info here, this is for classic tractors. Go to www. tractorbynet. com.
In general haven't heard much bad about the Montana's, and I've never heard of insuring a tractor, most people insure their property, including the tractor...
souNdguy
10-24-2006 06:13:18
I think he's likely refering to these montana tractors..
Soundguy
Engine Model Mitsubishi S4QS Output (gross horespower) 45 Rated Speed (rpm) 2600 Type Vertical, Indirect Cylinders 4 Bore x Stroke (in) 3.47 x 3.74 Displacement (cu in) 141.35 Air Cleaner Dual, Dry Element Cold Starting Aid Glow Plug Cooling System Water Cooled Fuel Tank Capacity (gal) ROPS 10.6 Power Take Off Independent PTO Standard PTO Speed (rpm) 540 Safety Interlock Yes Control Electro Hydraulic Power Train Synchro Shuttle Transmission 12x12 Creeper Standard Speed Range Forward (mph) .50 - 14.0 Foot Operated Differential Lock Mechanical Brake Type Wet, Multi-Disc Parking Brake Pedal Lock Steering Hydrostatic Hydraulics Controi Pos./Draft Sensing Pump Capacity (cc/rev) 12.87 Delivery (gpm) 8.43 Remote Valves (std/opt) (pt) 2 Lift Capacity Ball Ends (lbs) 3263 3-Point Hitch (category/coupler) 1/Yes Electrical System Battery Capacity 12v Working Light Yes Alternator 12v - 45A Axles Wheelbase (in) 68.7 Turning Radius (in) (w/ brake) 106.3 Turning Radius (in) (w/o brake) 117.2 Stardard Tire (front) 8.0 - 16.0 Standard Tire (rear) 12.4 - 24.0 Dimensions Length: Bumper to Link End (in) 131.2 Width: Tire Center (in) 51.4 - 66.0 Height: (in) ROPS 87.51 Ground Clearance (in) 13.2 Weight (w/o ballast) (lbs) ROPS 3815 source: http://www.montanatractors.com/pages/12_4540.html
Janicholson
10-23-2006 18:51:27
The only montana tractor I am aware of is BIG BUD www.bigbud.com there smaller unit was 450hp the bigger unit was 735hp V16. Take a Look. JimN
Janicholson
10-24-2006 11:48:57
 Re: montana tractor in reply to Janicholson, 10-23-2006 18:51:27
I'm glad it is badge engineering and has nothing to do with Montana. JimN
