Tractor Talk Discussion Forum
IH 5488 Engine Question
Tex Aggie
10-23-2006 15:35:57
On an IH 5488, I need some info on the motor. I am getting water into the oil. Does this motor have sleeves, or a straight bore? It has never been rebuilt, but looks like it is going to have to be now.
Any thoughts on why this may be happening?
thank you.
MIMark
10-23-2006 17:54:32
 Re: IH 5488 Engine Question in reply to Tex Aggie, 10-23-2006 15:35:57
could also be just the o-rings on the bottom of the sleeve but still not fun.
the tractor vet
10-23-2006 16:57:22
Yes it is a sleeved engine and if it does not have water filter then yep it's the sleeves now even though it may have a water filter it still could vary well be the sleeves or one other place to check before ya drag out the big wrenches is pull the valve cover as i have seen twice on the 414-466 the soft plugs in the top of the head leaking under the rockers. and then there could be the oil cooler or even and injector tube . So there is a bunch of could bee's , so pull the valve cover and the oil pan and let her drip for a couple days till all the oil stops drippen then place a big sheet of cardboard under it and pressure up the cooling system with about 15-20 lbs and start looken up .
showcrop
10-24-2006 17:00:37
 Re: IH 5488 Engine Question in reply to the tractor vet, 10-23-2006 16:57:22
My neighbors had one of those soft plugs give out on their 585. they didn't find it though until after they had done a lot of digging further down.
