Tractor Talk Discussion Forum
Re: removing distributor
Janicholson
10-27-2006 10:21:33
Only if you mark the base of the distributor and the enging in that location (base of distributor) to get it back to that same spot, because you are removing your index (clip)with the dist. JimN
B-maniac
10-27-2006 19:11:13
 Re: removing distributor in reply to Janicholson, 10-27-2006 10:21:33
Bottom line to what they are saying is this. The exact direction the rotor is pointing AND the exact position where the dist housing base bolts on MUST be marked AND recorded so it goes back in EXACTLY where it came out from. Also chalk mark the fan belt/pully so you can make sure the engine hasn't turned slightly before you put it back in. Just HOW you do all this is up to you,but this is what you need to do.
