Tractor Talk Discussion Forum
John Deere A what will it do the later style
cougar man
10-29-2006 12:35:48
i was tinking of buying ajohn deere and was looking at a late a with roll a matic and powertrol wanted to know how big of a disk and plow it will pull
Richard G.
10-30-2006 05:14:29
 Re: John Deere A what will it do the later style in reply to cougar man, 10-29-2006 12:35:48
Grew up on a 49 A and it pulled a Athens 5 disk tiller all day in heavy clay soil in 4th gear.
buickanddeere
10-29-2006 18:34:23
No water pump, no live hydraulics, no real three point hitch, no live pto, no power steering and a single barrel carburator..... why? The 60/620/630 for similar money you can have more HP, better fuel efficiency, less plug fouling, live hydraulics, optional live pto, optional power steering and on the 620/630 a factory built modern three point hitch.
farmerboy
10-30-2006 04:41:57
 Re: John Deere A what will it do the later style in reply to buickanddeere, 10-29-2006 18:34:23
Hey Buick, Whaddya call "similar money"? From what I've seen you can easily buy a a good running "A" around here (SC WI) between 1K and 1500. You won't touch a 620/30 for less than 4K and pry closer to 5000.
buickanddeere
10-30-2006 06:57:47
 Re: John Deere A what will it do the later style in reply to farmerboy, 10-30-2006 04:41:57
I should have been clearer. Around here an A and 60 run pretty close in bucks and a optioned out 60 just makes an A look sick. A 620 may go $1500 more, which is mighty economical for even more HP than the 60 and a proper three point hitch. The 630's do run up in your liste price range. Personally I think of the 20 and 30 series as the same tractor, just cosmetics are different.
Ken L.
10-29-2006 15:33:26
Guess it depends on the type of ground that you have. We have anything from nice loam to red & blue clay. My last A was a 51 and at times it had it's hands full with 2-14s as did my M IH and the 77 Olivers in the area. Pulled a 9ft disc.
long john
10-29-2006 15:24:11
John deere a was rated at 35 drawbar horsepower this makes it a 3 bottom tractor it is capable of handling a 12 disk. happy deere what gear can you pull your 2 bottom in i was doing 3rd with hardly any throttle with myn but its an eraly styled tractor. an a is a hard tugging tractor with alot of power plenty of weight good to work on and find parts for dont neccesarily care for the frame though if it was me i would try and find a 620 or 630 it is the same size but more power and confort, if you want to spend a little more i think you would be alot happier with it if your goig to work it. it really depends on the acrage if your doing a garden i use my h for that on about a 3 ace garden and it does fine
DP
10-29-2006 17:45:01
 Re: John Deere A what will it do the later style in reply to long john, 10-29-2006 15:24:11
620's and 630's are 10 HP bigger, but your right about the comfort issue. The live power, live hydraulics, power steering, float ride seat, and three point are a great improvement.
Josh in Pa
10-29-2006 14:02:13
It will probably handle 2-16's and an 8-10 ft disc. If you like older John Deeres I'd go for it, but if your looking for a working tractor, you can probably find something more capable for not much more money. Josh
HAPPY DEERE
10-29-2006 12:41:01
i go along all day long with my a with a 2 bottom 14 inch hydraulic plow it will do a 3 bottom 14 inch though but itll do the 2 bottom with ease on the plow there are 2types i like rope trip and hydraulic if yours has a thing called powr trol (((little box on the back))) in working condition you can use either type if not then i would recommend buying a rope trip
504-1
10-29-2006 13:56:45
 Re: John Deere A what will it do the later style in reply to HAPPY DEERE, 10-29-2006 12:41:01
We pullled a 3x16 JD hyd in 2nd gear for years but 3x14 would have been better. It was the same with a disc, we had a 12ft but the neighbors 10ft pulled a lot better. The bigger equipment was realy for our 70.
las vegas
10-29-2006 19:20:09
 Re: John Deere A what will it do the later style in reply to 504-1, 10-29-2006 13:56:45
maybe he LIKES the model "A"...and I really doubt a 620 comes near an "A" by a thousand bucks... not many people have a whole lot of money like most collectors with dupont paint jobs do...
buickanddeere
10-30-2006 06:59:00
 Re: John Deere A what will it do the later style in reply to las vegas, 10-29-2006 19:20:09
An A and 60 go for within a few hundred bucks of each other.
