Tractor Talk Discussion Forum
FARMALL M PTO
chad 9999
10-29-2006 18:06:40
I HAVE A M AND THE PTO HAS A BOX STICKING OFF THE REAR END HOUSING THE PARTS TRACTOR I HAVE DOES NOT HAVE THIS BOX IT IS ALMOST FLAT EXCEPT THE SHAFT THE TRACTOR WITH THE BOX IS MESSED UP AND I WAS WONDERING IF I COULD USE THE OTHER ONE IN ITS PLACE OR WHERE TO GET A TUBE FOR THE BOX STYLE
John M
10-30-2006 03:24:29
 Re: FARMALL M PTO in reply to chad 9999, 10-29-2006 18:06:40
As long as both ends are the same diameter, swap it. I have a 41 with the big unit,another 41 with the flatter unit and a 40 with the bigger unit.Both have the same diameter shaft.
John A.
10-29-2006 20:34:04
Chad, The tractor with the flat style PTO is the older style 1939-40 cira. The Bigger is the new style. To answer you question Yes it will work, But it is the smaller shaft annd needs an adapter. So check around the local wrecking yards and see if you can find a new style one. You will be more happy! Hope this helps.
Later,
John A.
OBTW... When you type in all CAPs it usually indicates that you are yelling, or really trying to make a point. Next time just talk to us don't YELL. We will get the point..... ja.
