Tractor Talk Discussion Forum
foil faced vapor barrier under metal roof
Tim, Ohio
10-31-2006 07:35:31
Hello Everyone,
I am currently building my pole building,
and have a little conflict of opinions concerning the foil vapor barrier. The building came as a package. A vapor barrier was supplied as part of
the roofing materials. It is white on one side and has a foil face on the other.
The company says I should install it with
the foil side facing the metal. It should
be pulled tight across the purlins, then temporarily stapled in place. The steel will lay directly on it.
Out of curiosity I searched the web for information about the installation and found a variety of ways which conflict with the company's approach. Some information
leads one to believe the foil should face down into the building. Some installations
have the stuff being draped over the purlins
so that it sags a bit to create an air space.
Most say the direction of the foil does not matter, but that by turning it down, towards the
inside of the building, it will not get dirty.
Since, once it gets dirty, it will no longer function as a radiant insulation.
At this time, I intend to just leave this building
uninsulated. So, this barrier is intended to keep the metal from sweating and dripping.
If there is anyone out there with any good
experience please let me know what you think.
Best regards,
Tim, Ohio
Bill in NorthCentral Pa
10-31-2006 12:11:21
 Re: foil faced vapor barrier under metal roof in reply to Tim, Ohio, 10-31-2006 07:35:31
Foil to the steel is the only way to install.
Good luck,
Bill
neblinc
10-31-2006 08:32:06
On my 40 x 50 shop that I am working on, I used the perforated foil faced on both sides on the walls & ceiling. Huge difference in heat transfer from the hot metal coming into the building. Before I put up the foil, I could feel all the heat radiating into the shop. Now I feel hardly any heat at all. The link below shows the walls done.
I would say to keep the foil side against the metal and also have an air space.
Randy
old
10-31-2006 08:18:11
I can only go by what I have seen. But all the ones I see go up have the white dwon and the foil up. Of course I'm also talking about the big one used in a factory but it should be the same in your case just smaller
john *.?-!.* cub owner
11-01-2006 10:36:47
 Re: foil faced vapor barrier under metal roof in reply to old, 10-31-2006 08:18:11
Whetehr it be steel, wood, or brick on the outside, the foil is a moisture barrier to prven moisture vapor from forming when the hot and cold meet, and show always to to the outside.
