Tractor Talk Discussion Forum
Tractor Hyraulics
al bane
11-01-2006 08:20:42
I have an 800 Ford tractor and the hydraulics are very slow. I have been using store brand hydraulic-transmission fluid . I was wondering what others use and what would speed the hydraulics up.
Don-Wi
11-01-2006 09:20:31
 Re: Tractor Hyraulics in reply to al bane, 11-01-2006 08:20:42
If you've got a loader run off of the tractor's own hydraulics, that's probably just the way it is with that tractor. Older ones ussually have lower GPM and PSI outpupts on the hydraulics, and it's just the 3pt. pump you're tied into for a loader, that's why they seem kinda slow. Even on remote cylinders there is a noticeable difference in speed.
The answer for a loader is to get a separate pump to drive off either the front of the crankshaft or the PTO in back. We've got a Massey 165 w/ a loader on it, has a front pump and I tied into the rear end of the tractor for the oil supply.
Donovan from Wisconsin
Bob
11-01-2006 08:25:35
If the label on the oil says it meets the Ford "134" specs, I doubt the oil you are using is the problem.
It sounds more like wear or other problems with the piston pump.
