Tractor Talk Discussion Forum
farmall m clutch
dougie75
11-04-2006 13:39:14
I have a 49 M with a clutch problem.It slips.My adjustment is"all the treads towards the front of the tractor"Does this mean I'm out of adjustment?And I seem to have a small rear main leak would that effect the clutch and can the rear main be changed when the tractor is split?
Thanks
Bryce
11-04-2006 15:08:09
 Re: farmall m clutch in reply to dougie75, 11-04-2006 13:39:14
Just so you know,you do not have to split it to change the clutch.
dougie75
11-05-2006 04:38:51
 Re: farmall m clutch in reply to Bryce, 11-04-2006 15:08:09
I have a 12" clutch,can i pull that without splitting? Thanks
Bryce
11-05-2006 04:45:45
 Re: farmall m clutch in reply to dougie75, 11-05-2006 04:38:51
You should be able to pull the hyd pump out the bottom and get at the clutch.
dougie75
11-05-2006 04:55:18
 Re: farmall m clutch in reply to Bryce, 11-05-2006 04:45:45
I'm sorry you were right,I do have an 11" clutch,that i can pull without spiltting,but another thing that i lost while pulling the tree yeaterday was my charging ability?generator?or what? Thanks again
Bryce
11-04-2006 11:08:44
 Re: farmall m clutch in reply to dougie75, 11-05-2006 04:55:18
Not real good at electrical without actually seeing it.Sorry
John M
11-04-2006 18:24:39
But you do to change the rear main.
Bryce
11-05-2006 04:43:29
 Re: farmall m clutch in reply to John M, 11-04-2006 18:24:39
You are correct.
John M
11-04-2006 13:43:45
Yes,Yes and Yes.
