Tractor Talk Discussion Forum
Farmall Super C
FarmallBob
11-04-2006 14:08:00
I would like to make an adjustment to my front end on my Super C. The the tires are pointing in.
Can someone tell me what to do? Any help much appreciated. Thank you.
Bob
504-1
11-04-2006 19:20:52
 Re: Farmall Super C in reply to FarmallBob, 11-04-2006 14:08:00
And if it is a narrow front, that is the way it was made.
tractorsam
11-04-2006 14:17:07
How much are they pointing in? They should be pointing in a small amount (in the region of 1/2" front to back). Presumably your tractor has a wide front end. If so and it hasn't been moved in a while it could be quite a job. tractorsam
FarmallBob
11-04-2006 22:51:44
 Re: Farmall Super C in reply to tractorsam, 11-04-2006 14:17:07
The tractor is a WFE and it cut up my back lawn. They are pointing in about 2inches on on side and about 1/2 inch on the other. Joints look OK the tie rods look a little bent. Thanks!
Bob
RayP(MI)
11-04-2006 17:02:35
Couple of other things to check, assuming it as a WFE, what is the condition of the ball joints, and have the tie rods been bent? Repair or replace as necessary. This may well take care of any mis-allignmrent. Next step will be far more difficult!
