Tractor Talk Discussion Forum
9n wheel assembly(rear wheel)
vancerr
11-04-2006 20:04:50
Wheel assembly is hung up, are there keepers on it? left rear leaks, and I can't get it off to fix
RAB
11-05-2006 00:33:20
 Re: 9n wheel assembly(rear wheel) in reply to vancerr, 11-04-2006 20:04:50
The "quick fix" is to mend the leak it while still on the tractor. May depend on your circumstances. May not have the tools, may not be able to pump it up enough to loosen the wheel as suggested. Depends what is holding up the wheel - spigot or sh1t around the studs. Sometimes jacking across from something solid will shift it, especially with some help from a sledge.
HTH.
Regards, RAB
old
11-04-2006 20:35:33
Put the bolts back on loose but not real loose. Air up the tire and then drive it around a little. You should here when it pops loose from the center and then just jack it up and remove the bolts and pop it off.
vancerr
11-04-2006 20:59:23
 Re: 9n wheel assembly(rear wheel) in reply to old, 11-04-2006 20:35:33
Thanks again. Its been hard getting info. most shop manuals aren"t that good. not the real manuals that a shop would use
old
11-05-2006 07:27:16
 Re: 9n wheel assembly(rear wheel) in reply to vancerr, 11-04-2006 20:59:23
That method wouldn't be in any manaul its the method learned by the road of hard knocks LOL
