Tractor Talk Discussion Forum
O/T Proper way to engage 1993 4X4
frankiee
11-07-2006 04:13:24
Proper way to engage 1993 4X4 on Chev Suburban
Mike M
11-07-2006 06:44:45
 Re: O/T Proper way to engage 1993 4X4 in reply to frankiee, 11-07-2006 04:13:24
Pull down your sunvisors and see if the directions are still there.
TimS in Mo
11-07-2006 05:09:50
I had a 94 gmc 1/2 ton with 4x4, it had the stick on the floor. To go from 2 high to 4 high I would just let the truck coast ( foot off gas to unload the drive train ) and pull the lever to 4 high and wait for the indicator to light up that it had got done shifting. To get into 4 low you had to stop and then shift to 4 low if I recall correctly.
john cub owner
11-07-2006 05:15:51
 Re: O/T Proper way to engage 1993 4X4 in reply to TimS in Mo, 11-07-2006 05:09:50
To get many of the older 4x4 out of 4wd you could hold a steady pressure against transfer case shifter while gently depressing and releasing the gas pedal. this was done while moving.
