Tractor Talk Discussion Forum
Removing foam insuation
BSer
11-08-2006 15:46:19
I want to use the floor of an old reefer trailer to deck a car trailer. There's a 4 inch coat of spray foam that resists pressure cleaning. Is there anything that will disolve this? Scraping uglies up the aluminum and sandblasting pits it. I'm desperate for ideas..... .
KEB
11-08-2006 20:36:55
 Re: Removing foam insuation in reply to BSer, 11-08-2006 15:46:19
Acetone will dissolve most foams. Probably want to scrape off as much as you can without damaging the underlying metal, then use whatever solvent works to take the rest off. You might also try using a plastic scraper (snow shovel, maybe???) to minimize damage to the underlying metal.
Good luck, doesn't sound like something I'd want to tackle.
Keith
old
11-08-2006 17:13:22
Gas, paint thinner etc will melt it away. If you where to put it on a slant and then pour something like that on it that might just do the trick, but it also might not just an idea
oldart
11-08-2006 16:00:35
flame thrower. or go to a floorihg place and see what they use to remove tile it is a knife that wiggles back and forth might work good luck
