Tractor Talk Discussion Forum
B- Allis or C - Farmall
Nat
11-09-2006 16:47:54
I have one of each. I put a 3PH on each, and each work well with the farmall having live lift where-as the Allis has a trans driven pump. I want to know what yall thing on the comparision of the 2. Tric C and w/front on the Allis. I pull a 5" box blade and a 5" rear finish mower , a 3PH set of forks to move light pallets around and a 6" landscape rake with either tractor. How about some opinions from people that owned either/or. I have been using each trying to figure which I like the best, which is the easiest to mount/dismount. The Allis is 2 one finger turns lock to lock and the Farmall is 4 1/2 turns lock to lock and it steers easy. I don"t think there is 1/2 HP difference and not 100 lbs of weight difference. What do you think?, later, Nat
Link
http://www.tractorshed.com/gallery/tphotos/a37888.jpg
old
11-09-2006 17:47:16
 Re: B- Allis or C - Farmall in reply to Nat, 11-09-2006 16:47:54
Each one will have its good points and its bad points. I have had an Allis B before and now have 2 Allis C which at close to the B other then haveing a trike front on them. Each tractor you have will do differant things better. One may work better for mowing then the other becuase of things like ground speed. To me I could never live with just one tractor, shoot I have around 30-35 of them
