Tractor Talk Discussion Forum
Clunky rear end 530
Mike Veen
11-11-2006 19:26:25
I have a 1965 case 530 ck backhoe.I"m getting a clunk,clunk,clunk as I"m driving along.Sounds like it"s coming from the diff.I"ve taken off the brake covers(needs shoes).But with the covers off and brakes out it still clunks.(Front bucket makes a good brake).Any Ideas?
coflyoy
11-12-2006 08:50:19
 Re: Clunky rear end 530 in reply to Mike Veen, 11-11-2006 19:26:25
I just mothballed my tractor for the winter. Found ALL of the front wheel lug nuts loose.
Allan In NE
11-12-2006 04:04:35
Mike, STOP!!!
Check all the lug bolts and cinch bolts on your axle/wheels.
Had a neighbor get killed when they came loose and the wheel came off throwing him from the tractor.
Allan
K-Mo
11-11-2006 19:48:39
Good possibility of a bad tooth on the bull and pinion gear. Jack up one rear wheel at a time and give it a spin. The side that clunks will be the side with the bad bull and pinion gear. If you continue to drive, it won't get any better. If the bad teeth bind, it could do a lot more serious damage.
K-Mo
Mike Veen
11-11-2006 20:37:22
 Re: Clunky rear end 530 in reply to K-Mo, 11-11-2006 19:48:39
Just started today.Started of a hard to hear clicking,then it got louder after 15 min.Shut it off and started to check things.I'll try one side at a time.Thanks.
K-Mo
11-12-2006 05:34:18
 Re: Clunky rear end 530 in reply to Mike Veen, 11-11-2006 20:37:22
Yes, check the simple things first. I may have jumped the gun talking about the bull pinion. When you said "clunk" I clearly heard the same "clunk" I had in my 580CK when a tooth broke on the bull pinion.
Mike Veen
11-12-2006 19:46:00
 Re: Clunky rear end 530 in reply to K-Mo, 11-12-2006 05:34:18
Broken teeth on crown gear and play on the bearings on the brake end of things.
