Tractor Talk Discussion Forum
Sediment Bowl
huningreen
11-12-2006 18:37:38
Do any of you have the same problems I have when I have a sediment bowl off and re-install it. If I put it on tight enouh to not leak it won't flow fuel. Had that problem today with a H Farmall. Any suggestions will be appreciated.
Harold Hubbard
11-13-2006 05:25:41
 Re: Sediment Bowl in reply to huningreen, 11-12-2006 18:37:38
I would rather have it do that, than fill up immediately and start dripping.
Michael Soldan
11-13-2006 04:55:17
Huningreen,what the others said, but I guess I just like it full so I turn the fuel on slowly with the bowl setting loose, as the fuel nears the top I turn the tightener, just when it overflows I turn it all the way tight, bowl is full and I wipe off the glass and check for leaks..to each his own, but the others are quite correct...Mike in Exeter Ontario
huntingreen
11-13-2006 10:19:15
 Re: Sediment Bowl in reply to Michael Soldan, 11-13-2006 04:55:17
Thanks Mike. Glad someone on here can be of help without getting smart. I had the fuel line completely off the carb so I don't know what the problem is. Before I pulled the bowl off it was flowing fuel. Bowl was just full of water.
old
11-12-2006 19:40:35
If your talking about it not filling then the problem isn't the sediment bowl but in your head./ All it means is the carb is full of gas and the float is holding the needle closed so NO gas can flow. Start the tractor and watch the sediment bowl, it will fill in less then a minute. Works the same way as takeing a drinking straw and hold the end closed with your finger, then put it in a glass of soda and what happens?? The straw will not fill woith soda till you remove your finger, works the same way on the tractor fuel system and sediment bowl
Bob
11-12-2006 20:52:59
 Re: Sediment Bowl in reply to old, 11-12-2006 19:40:35
Good post, Old!
I wonder what percentage of folks freak out when the sediment bowl doesn't immediately fill when they turn the gas back on after cleaning it!
You hit the nail on the head with your explanation of how the sediment bowl won't fill if the carb is already full of gas, and the float is holding the needle shut.
old
11-13-2006 08:30:23
 Re: Sediment Bowl in reply to Bob, 11-12-2006 20:52:59
Bob, I see people post this same question over and over again and ya they freak out because the bowl dosn't fill then of course they ask here. So for once I figured I would try to expalin to this person why it works like it works
Mike M
11-13-2006 04:47:17
I can't remember if I freaked the first time or not ? Now I know that I have a leak free system.
bo
11-12-2006 18:46:53
needs a new gasket...get one or make one.
504-1
11-12-2006 20:29:36
 Re: Sediment Bowl in reply to bo, 11-12-2006 18:46:53
what Old said.
