Tractor Talk Discussion Forum
Battery case repair
Wardner
11-14-2006 20:21:44
Somebody gave me a new Cat branded battery (4D sized) that had a dime sized hole on the top. I filled it with acid and patched the hole with plastic cut from a junk battery. I used an epoxy repair adhesive and applied it to the quarter sized patch and the adjacent areas around the hole. I cleaned and abraided both the case and the patch.
I noticed the other day that the repair was not successful. I need suggestions on how to make a permanent repair to this battery. Thanks
Loren in MN
11-15-2006 09:41:29
 Re: Battery case repair in reply to Wardner, 11-14-2006 20:21:44
I bought a tractor which had been in a fire. It had a new battery but the top had melted with a couple leaking holes. I put some thick roofing tar on the battery top -needed to cover most of the top. The battery worked a couple more years.
Bus Driver
11-15-2006 04:08:03
Many of the new battery cases are polypropylene. Heat welding is the only way to repair broken polypropylene. I know of no adhesive that bonds to it.
RAW in IA
11-15-2006 02:34:24
Yearsago I had a battery blow it,s top( One cell anyway). I put it back on with Silicone. Worked for acouple of years till the thing went belly-up. Just cleaned up the parts and battery top and put it back together with the silicone.
Keith-OR
11-14-2006 21:54:05
Go to your auto glass shop, see if they have a partial tube of windshield urathane (stuff they use to install windshield). It adheres to anything and everything. Besure to wear gloves as if you get any on your hands, only way to get it off is to wear it.
Keith & Shawn
GeneZ
11-14-2006 21:44:17
Take a piece of plastic from an old battery a little bigger than the hole. Use a propane torch to warm up the plastic piece and then warm up the spot around the hole you want to repair. Then slap the two melted pieces together. This worked for me to fix a crack in the bottom of a battery. I just had to drain the acid out.
RAB
11-14-2006 23:03:39
 Re: Battery case repair in reply to GeneZ, 11-14-2006 21:44:17
If you get a flame anywhere near a battery, make sure the battery has been well vented. An explosion can be the result if hydrogen gas is present.
Regards, RAB
135 Fan
11-14-2006 21:22:08
I bought a reconditioned battery and it had a small crack by one of the posts. They took an electric soldering iron and melted it together. Maybe you could do this with your patch. Dave
old
11-14-2006 20:50:23
Don't know if you can get it any more but years ago they made something just for that. I usto get the stuff at my local O'reillys auto parts stores
