Tractor Talk Discussion Forum
flywheel starter gear
Charles Lindsey
11-15-2006 19:08:55
I have a Allis Chalmers C that I am restoring, question Can the flywheel starter gear be turned around? Thanks.
Charles
msb
11-16-2006 07:20:21
 Re: flywheel starter gear in reply to Charles Lindsey, 11-15-2006 19:08:55
Sure, just put a little heat on it to expand it and it will come right off.Don't just heat it in one place.Mark its location first and then quarter its location.4 cylinder engines will always stop in only one of two places anyway.No need even to reverse the side of the gear.Heat it in an oven to make it easy to reinstall.Putting the flywheel in a freezer over night will let you drop the gear right into place.Then splash a little cold water on the gear to shrink the gear back on tight.Some people then put a couple spots of weld on them.
john cub owner
11-16-2006 05:57:00
If your problem is the ends of the teeth being battered and the starter not engaging, use a thin wheel in a angle grinder to reshape them.
Bob Da. (La)
11-16-2006 03:54:52
You probably could but for the hassle of possibly having to change it again in the near future I wouldn't. New ones are reasonable. Check this site's parts or search Allis chalmers for other sources if not available here. God Bless. Bob Da. (La)
