Tractor Talk Discussion Forum
5020 JD shifter
Delta Bob
11-17-2006 16:11:33
Is there a rebuild kit available for a 5020 JD synchro shifter?
37 chief
11-17-2006 18:12:49
 Re: 5020 JD shifter in reply to Delta Bob, 11-17-2006 16:11:33
My 5020 was also very hard to shift gears. Linkage was very loose, which was most of the problem. I was able to get some repair parts from JD to remove most of the play. I even made some over sized clevis pins. remove all the slack you can. Stan
Glen in TX
11-17-2006 18:01:24
Enter 5020 in the online parts catalog to find what you need for it. Price it by registering with local dealer on http:jdparts.deere.com Doubt you'll find just a kit but parts seperately. Get the linkage and dash shifter wear fixed first before you have to tear into it and check shifter arms on outside for wear also.
Delta Bob
11-17-2006 19:12:52
 Re: 5020 JD shifter in reply to Glen in TX, 11-17-2006 18:01:24
Thanks everyone for the help.
HAPPY DEERE
11-17-2006 16:50:51
if you want a rebuild kit you should be able to get it at john deere
