Tractor Talk Discussion Forum
Adding a PTO
T
11-18-2006 06:00:40
I got a Steiger Cougar built in 1973 I would like to add a PTO to it, what do I need? I figure on using a hydraulic motor and just couple it up to a unused remote, 540 RPM would be all I need.
Can somebody tell me what hydraulic motor to buy for this application?
MSM
11-18-2006 07:57:04
 Re: Adding a PTO in reply to T, 11-18-2006 06:00:40
Unless it is a very slight load(5-10 hp(,a hydraulic motor will probably not do the job you want.To have any power, the motor will have to be fairly large,then add a gearbox to drive the shaft,plus it will take alot of oil flow to run it,and require a motor spool in your valve bank.While it is running,I doubt if you will have enough pump flow in reserve to even operate a cylinder on another remote without affecting the power and speed of the pto.
Abilene Machine or Big Tractor Parts have salvaged a number of Steigers and will probably have a take out PTO assembly for your tractor but it will be the large diameter 1000 rpm stub.
MN Bob
11-18-2006 07:27:42
Got my new Farm Show, page 19 has a Add on dual PTO for stationary engines. Dont know if it will work or they might make one to fit your needs. Beiler Engine and Mfg. Georgetown RD Christiana Penn. ph. 717-529-6595. Hope this helps, good luck. Bob
Roy Suomi
11-18-2006 06:14:03
I remember seeing a motor with a PTO spline built in..I think maybe , Surplus Center.com Also you will need to get a motoring valve to operate the pto motor..This will allow you to start and stop the motor without a sudden jolt starting and a "hydraulic lock" stop..This valve has small cuts in the side of the spool that will allow the hydraulic pressure to bleed until the spool is fully engaged..You can install this valve after the remotes ,inline , with a return line from valve exhaust going back to sump..
BarryfromIA
11-18-2006 06:34:34
 Re: Adding a PTO in reply to Roy Suomi, 11-18-2006 06:14:03
Be sure your sales person for the motor understands your aplication. Some motors will not withstand any side loading on output shaft. It can seen on disasembly after it fails.
