Tractor Talk Discussion Forum
Parking a tractor
550Doug
11-21-2006 06:12:19
I have a tractor to park and tarp over the winter. It will be outside on a sloped piece of ground. What is the best way to leave the tranny :
1. in reverse with no wheels blocked, load on tranny
2. in neutral with wheels blocked
3. in neutral with brakes locked on
4. in reverse, wheels blocked, load on tranny
5. in reverse, wheels blocked, no load on tranny
6. other??
Also, should the whole tractor be placed on blocks?
Thanks
Bill from MA
11-21-2006 17:06:26
 Re: Parking a tractor in reply to 550Doug, 11-21-2006 06:12:19
I have bought but not been able to use it yet as my JD 2040 is out of state but have read in sports car forums that this smart charger is one of the best.
Link
Bill
showcrop
11-21-2006 14:17:09
Doug, If I were you I wouldn"t tarp it unless there is no wind. otherwise, you will get places where the tarp wears your paint.
Mike M
11-21-2006 12:35:39
Something else to think about ? If you don't block the clutch pedal down it may stick as well. I don't have any good answers as to leaving them outside except DON'T.
RAB
11-21-2006 12:30:07
We don"t have a great problem of clutches sticking but something to consider, so perhaps if you need to wedge the clutch pedal and leave the brakes off you need to find some flat ground. Maybe wet discs anyway and no problem there?
BTW, is this on the top of a mound? Must be enough space somewhere to turn it along the slope to leave it safe.
Regards, RAB
RodInNS
11-21-2006 09:32:16
If it were mine, and I was real particular, then I'd change the engine oil, grease it up, check the cooling system.... Then park it, in low gear. Don't set the brakes. I might disconnect the battery cable. I probably would not. I've left them sit just like Allan's for a couple months on end, depending on what use I had for one.
Actually, I just recommisioned an old highway tractor on the weekend. She sat where she was parked for 2 years with a twisted frame. It got parked there the first week of December, '04. I was so disgusted, I just got out and left it. Scrap. Checked nothing.
Checked the oil and antifreeze the other day, put her on the block heater, cleaned all the cable connections and stuck 2 new batteries in the box, and another big set of booster cables bolted to the other truck to help. Fill the fuel filter(Cummins) and dump 5 gallons in the saddle tank.... crank and off she went. This just went too good. Had to try the clutch. Oh boy, it's not stuck. Try the gears. Yep, they all work. Got some air up, release the maxi's... Well, only 2 drums are stuck. Lock the power divider and tug.... Rocked her about 5 times back and forth, and the drums released. What the heck, I'm going for a joyride..... Mind you, this old junk sat for 2 years without so much as being turned over.
I think some people overthink the storage part of old tractors. I wouldn't exactly recomend what I did to that old truck.... but for a short period of time, it'll be just fine all by it's lonesome. Just cover the exhaust so it doesn't get water in, and make sure the antifreeze is up to par for your climate. Check all the fluid levels before you recommision the thing.
Nebraska Cowman
11-21-2006 07:39:14
Don't you have any level ground or do you live in Missiouri?
Hard Knocks
11-21-2006 23:41:39
 Re: Parking a tractor in reply to Nebraska Cowman, 11-21-2006 07:39:14
Here in Virginia half the diesel tractors don't need batteries just roll them off a hill.Biggest problem baling hay is run away bales.
Walter Squires
11-21-2006 08:26:29
We don't have to have a tow vehicle to start one we just roll it off a hill :)
Walter Squires, Springfield, MO
Jimmy King
11-21-2006 10:43:11
 Re: Parking a tractor in reply to Walter Squires , 11-21-2006 08:26:29
Hey Walter, how are you this fine day. I had a cousin that was raised in Texas she married a farmer from Connersville, Indiana. The first time Chuck was here for a few days he kept saying how do you farm in these rocks. About the third day my uncle said well Chuck what on earth do you scotch your wagons with.
Sam (MO)
11-21-2006 07:56:05
Hey Cowman
WE here is Missouri won't know how to park anything without wheel blocks.
Sam
Nebraska Cowman
11-21-2006 08:30:08
 Re: Parking a tractor in reply to Sam (MO), 11-21-2006 07:56:05
And MO is the only place I know where you can get chiggers wearing boots and never step off the blacktop. You have a nice state and I am looking forward to Red Power in 2008. I'll bring my own blocks.
Tim...Ok
11-21-2006 08:47:30
 Re: Parking a tractor in reply to Nebraska Cowman, 11-21-2006 08:30:08
Missouri,Arkansas and Oklahoma in July you can get chiggers by seeing weeds on TV..
Tim still scratchin LOL
Sam (MO)
11-21-2006 08:35:56
Cowman
Maybe just maybe I'll have that 49 H ready to go. SHe is one rough puppy. When and where is the Red Power 2008???
Nebraska Cowman
11-21-2006 10:09:44
 Re: Parking a tractor in reply to Sam (MO), 11-21-2006 08:35:56
Columbia or closeby. I am not sure they have a site picked yet.
Aaron Ford
11-21-2006 07:39:13
If its anything like my parents 135, go down to the docks and get ya an anchor. A big one. Darned thing has rolled off a couple of times now. No operator fault, no sir. Well maybe sorta,...
I would leave it in gear and block the tires for safety. Locking the brakes could cause problems if ya need it in the winter. Rust could also set in.
Heck move it a couple of times if it makes ya feel better.
HTH Aaron
glennster
11-21-2006 06:40:08
i would leave it in neutral, brakes unlocked. raise the tire pressure up to 25 psi or so so you wont get a flat spot. park it on some pieces of plywood so the tires dont sit on the dirt, chock the wheels so it dont roll down the hill. maybe spray some fogging oil in the carb with the engine running to coat the inside of the motor.
Allan In NE
11-21-2006 06:24:13
Dunno,
I've heard that ya have to always bring 'em in the house, place 'em close to the fireplace and spoon feed with hot cereal all winter long so they don't catch a cold 'er somethin'. :>)
Allan
third party image
730virgil
11-21-2006 19:30:22
 Re: Parking a tractor in reply to Allan In NE, 11-21-2006 06:24:13
Allan aren't you afeered they'll catch pmomia or something ?
GeorgeH
11-21-2006 09:18:50
As my wife would say, "poor babies".
Keith-OR
11-21-2006 07:29:00
Morn Allan, Is that a Danuser auger? Sure looks like the one I have sitting out back....
PS.. keep all that white stuff out there. Just bale it and spread it next summer..:>)
Keith
Sam (MO)
11-21-2006 06:30:21
Hey Allen
sure wish I had that auger and you had a feather, we both be tickled. Cause I can't seem to dig a straight whole.
Sam
Allan In NE
11-21-2006 06:37:25
 Re: Parking a tractor in reply to Sam (MO), 11-21-2006 06:30:21
Oh Heck,
Me neither. Even went and got a smaller 9". Didn't help one darned bit. :>(
Oh well, critters haven't complained yet. :>)
Allan
Sam (MO)
11-21-2006 06:57:12
 Re: Parking a tractor in reply to Allan In NE, 11-21-2006 06:37:25
yep, those critters sure like standing there supervising my work.
Hope to be hanging some gates soon.
Sam
