Tractor Talk Discussion Forum
Re: OT 1996 Ford Powerstroke problems
Brokenwrench
11-21-2006 15:20:54
You`re right on, after I posted, I realized I was refering to the warm up valve.
Jeff Oliver
11-21-2006 16:02:22
 Re: OT 1996 Ford Powerstroke problems in reply to Brokenwrench, 11-21-2006 15:20:54
ok thanks guys, I wasn't sure what it was called but I knew what it did. I'll check that site and see what it says. If i let it warm up a few minutes before driving it shouldn't hurt the turbo with the warm up valve disconnected will it?
Blue guy
11-21-2006 18:50:37
 Re: OT 1996 Ford Powerstroke problems in reply to Jeff Oliver, 11-21-2006 16:02:22
It should not hurt a thing being disconnected. I would try it and see if that is what is causing your trouble. Only downside from being unplugged is slower warm ups.
John M
11-21-2006 16:57:49
Its called an Exaust Back Pressure Valve, EBPV for short. If its doing it when its warm utside as well as cold, you proably have a bad sensor for the EBPV. It shouldnt close when its warm outside.
Jeff Oliver
11-21-2006 17:31:43
 Re: OT 1996 Ford Powerstroke problems in reply to John M, 11-21-2006 16:57:49
thats what i thought but the mechanic at the dealership says he put it on the machine and the sensor checks fine. I think it still takes too long to open when it is cold as I would think 20 minutes of warmup should be plenty. I found the link on how to take the guts out of it but from looking at the pictures I'm thinking you might be able to take it apart and clean up up and lubricate the valve to where it will work right.
I'll research more.... :)
John M
11-22-2006 03:29:15
 Re: OT 1996 Ford Powerstroke problems in reply to Jeff Oliver, 11-21-2006 17:31:43
Was the engine cold when he checked it? If it was warm then the sensor will be "on" to open the EBPV.I still think thats the problem.
