Tractor Talk Discussion Forum
JD 70D
Grumps
11-23-2006 14:16:05
I have a JD 70D I pull in the 7500 & 8500 classes it does great in the 7500 class but needs a bit more power in the 8500. Does anyone have any suggestion on a few more cheap Horses. Have the rack at 13 and a K&N filter, everything else on engine is stock.
Jack as
11-24-2006 04:14:06
 Re: JD 70D in reply to Grumps, 11-23-2006 14:16:05
Is this a stock class or is modification allowed? I pull in stickly stock with my Allis and do real well in the 7,500# and 8,500# classes. Just weight it right (a good guess) and play the throttle up and down when the front end gets light. I have never powered out though.
buickanddeere
11-23-2006 17:36:00
720/730 cylinder heads flow more. A three angle valve job, valve blowl blending and port matching will improve any head. Check the part number, there maybe a 720/730 head on there already. A cam from Robert's Carburator will increase airflow. More fuel is easy, more air to burn the extra fuel is the tricky part. I assume this is a rowcrop with tall tires?
Grumps
11-24-2006 11:37:50
 Re: JD 70D in reply to buickanddeere, 11-23-2006 17:36:00
Thanks for the reply Buickanddeere, yes it is a row crop with 18.4 x 38 rubber I tried some 30" rubber and had more power to the ground but no grip,I may try a performance cam and some 6-.010 injector tips. Thanks again
504-1
11-23-2006 14:25:32
Add a little propane to the intake sure would make an old Cummings bark.
grumps
11-23-2006 14:35:08
 Re: JD 70D in reply to 504-1, 11-23-2006 14:25:32
I"m sure propane would help but can"t use it in antique pull
