Tractor Talk Discussion Forum
ford
donnie sanders
11-23-2006 15:27:17
does any one know if a hi/lo trans, assembly out of a 9n with the three speed,fit the 8n with the four speed transmission. Any info will be very helpful. Thanks Donnie Sanders
jimNCal
11-23-2006 18:07:43
 Re: ford /Sherman swap in reply to donnie sanders, 11-23-2006 15:27:17
Only the earliest 9n's had the straight-cut input gear. You should be fine. Should you find you DO have this straight gear after you split the tractor to install the Sherman, your dealer will have the replacement gear anyway, so not to worry. Good luck and work/split safe,
jim
lanyon
11-23-2006 17:04:01
 Re: ford in reply to donnie sanders, 11-23-2006 15:27:17
The aux.transmission out of a 9N will not fit a 8N the input gear on the 9n has stright teeth and the 8n has angle teeth.
old
11-23-2006 16:31:33
Pretty sure that it will work just fine, other then haveing to spit the tractor and drilling a hole for the shifter its a piece of cake to install
