Tractor Talk Discussion Forum
hard steering to the left...
roy hill
11-25-2006 08:44:34
my 1830 john deere tractor has no power asist when i turn to the left.... when turning to the right i have power assisted action.... ihave cked the front end for any binding but found everthing ok. any ideas?? thank you very much!! ( the tractor was manufactered in 1976}
Dan-IA
11-25-2006 20:52:07
 Re: hard steering to the left... in reply to roy hill, 11-25-2006 08:44:34
We've established in the past that I know nothing when it comes to green paint so that this with a grain of salt, but...
Were this an IH tractor, I'd be looking first for leaking hydraulic oil. If that's not a problem, I'd probably pull the hydraulic hoses to the power-steering cylinder (one at a time), stick it in a bucket and see what kind of flow you get, when the steering wheel is stationary and when you're turning it. I'd probably pull the right one first so you know what to expect, then the left one. If flow seems dramatically less on the left side, then I'd check for a constriction in the hose. Failing that, I'd think about pulling the power-steering actuator behind the steering wheel and giving it a good look over (or have a hydraulic shop check it for you.) Don't forget to refill your hydraulic oil and bleed the air out of the system.
Something else I'd check (first) is to see if you hear a pressure-relief valve chattering, especially during a left-turn. If so, that'd be where I'd start.
But like I said, I'm an IH guy. My one green tractor (an A) doesn't have any power-steering. So good luck with that.
