Tractor Talk Discussion Forum
what do you guys think?
Tim Shultz
11-26-2006 09:57:06
third party image
I need a reciver hitch for my truck, so that I can use a drop hitch to pull a bumper pull trailer.. my question is do you think this would work, in the picture what is marked red is gone, and the yellow arrow is where I would weld a square tube for the reciver.. think it would work? some say the hitch would not be safe for highway use, but I have pulled a loaded hay wagone with no problem, mind you this is a wagone that sways and jerks really bad.. so what do you think? thanks for your input! Tim Shultz
NEsota
11-26-2006 12:55:00
 Re: what do you guys think? in reply to Tim Shultz, 11-26-2006 09:57:06
I bought a like new, receiver hitch for $40 at a salvage yard that bolted right onto my Ranger. It had been sold by Uhaul, was quality and I would not have thought of going to a salvage yard for it but saw it when getting other parts. It easily saved me $40 worth of time as opposed to fabricating one.
Glen in TX
11-26-2006 12:22:34
If you cut that off and that center tounge out too it should work fine. Just be sure to move the square tube in far enough and gusset and also angle some heavy iron braces from existing bumper forward to frame so it won't fold under with heavy tongue weight on it. I've done several of the el cheapo bumpers by cutting out the center and ended up with something heavier than could be bought. If that's a air tank type bumper you have now and mounting irons are only welded on outside you need to start over or find something else though because it will pull off. Check junk yards and might find something ready to go?
Don L C
11-26-2006 13:57:27
 Re: what do you guys think? in reply to Glen in TX, 11-26-2006 12:22:34
What works well when adding a square hitch to a truck frame is.....weld a length of 2" tubing(4 to 6'long) from the front end of the hitch tube on to a cross member using a 4 or 5" piece of 3/8" angle to the front end and bolt it to the cross member....bolt the angle on then weld the 2" tube on that way it is bolted soild and level, tube can be weiled at a angle.....result is a very strong hitch.....
Glen in TX
11-26-2006 15:00:39
 Re: what do you guys think? in reply to Don L C, 11-26-2006 13:57:27
Sounds good and might help keep the mud out too ?
RustyFarmall
11-26-2006 11:00:37
Pulling a wagon will not be a problem, however, if you tow anything that actually puts weight down on the hitch, you will have problems. I would suggest a commercially built hitch that bolts to the frame of the truck, or better yet, scrounge up some iron and build what you need. Build it extra heavy duty, and then you can transport some of the big farm equipment also.
oldart
11-26-2006 14:31:32
 Re: what do you guys think? in reply to RustyFarmall, 11-26-2006 11:00:37
what ever you do end up with a step to get up into that truck bed.
