Tractor Talk Discussion Forum
Help engine swap from an H into 300 utility
sunny 4 acres
11-26-2006 14:36:46
Hello Folks. I need to know if it is possible to easily swap an engine from an farmall H into a 300 utility without heavy mods. Any help would be appreciated. Posted on farmall forum but recieved zero help
Leroy
11-27-2006 05:04:37
 Re: Help engine swap from an H into 300 utility in reply to sunny 4 acres, 11-26-2006 14:36:46
You would be loosing about 1/4th of the horsepower of the 300
D Slater
11-26-2006 18:48:15
Yes, mostly bolt in using 300 flywheel and clutch. Only big change is the engine front cover needs changed to utility one and some of the bolt holes taped in the H block that hold cover on are taped for a smaller diameter bolt than utilty uses.
