Tractor Talk Discussion Forum
Daytime Run. Lights.
Jim@concordfarms.
11-27-2006 10:58:55
Anybody know how to disable the day time running lights on a '99 GMC Sonoma? I've promoted-retired the old truck to farm duty only, and I don't need to have the lights burning when I'm out on the farm hauling fence posts or feed, but I still want the lights available at the swith if I need them. Many thanks for any help. Jim.
Allan In NE
11-27-2006 12:25:46
 Re: Daytime Run. Lights. in reply to Jim@concordfarms., 11-27-2006 10:58:55
Jim,
Take a peek in your owner's manual. It tells you exactly how to disable the gizmos.
Allan
CLW
11-27-2006 12:12:11
As said below, press the emergancy brake about one notch and it will turn them off, yet it still will not put a drag on the brake. If it was like the 2000 model I use to drive they will burn out often anyway. You should be able to mount an on/off switch under the dash and tie it into the wire going to the brake switch if you don't trust the emergancy brake way of turning them off.
Brad in WI
11-27-2006 11:28:43
I had a '02 chevy S10 and if you pushed the dome switch? 4 times it would shut them off. (The button next to the light switch) Look in the owners manual, it might say how to shut them off.
RustyFarmall
11-27-2006 11:27:14
On my '01 Chevy the running lights are separate from everything else, so potentially a person could just disconnect them. On the '98 I had previously the running lights were included I think in the headlights, but were still a separate bulb, so again they could just be disconnected. I think your owners manual should have a wiring diagram in it. Maybe you could study it and find a way?
Leland
11-27-2006 20:26:29
 Re: Daytime Run. Lights. in reply to RustyFarmall, 11-27-2006 11:27:14
rusty as posted above just push the domelight over ride button 4 times or until you hear a ding
Txsprigger
11-27-2006 11:21:09
step on the emergency brake ever so slightly, they should go off.
bjb in Ne
11-27-2006 11:15:57
Are you saying this truck will never be on a road ever again. If not leave them alone. The whole purpose of them is for visablity not only at night but also in the day. I would just leave them alone.
MikeinKy
11-27-2006 16:31:35
 Re: Daytime Run. Lights. in reply to bjb in Ne, 11-27-2006 11:15:57
I don't know about a Chevy, but on my 2000, F150, they are on a seperate fuse. It is hidden under the top of the dash. I had to ask a mechanic at my local dealer about it. I pulled it and now I can have lights when I want and turn them off when I want.
