Tractor Talk Discussion Forum
Power Wagon wheel cylinders
Roy Suomi
11-27-2006 15:06:50
Well , I tried the truck forum at the bottom of YT..No Hits yet....I've got a 1965 W300M Dodge Power Wagon [ looks like a '49 ]..About 7 years ago I took the brakes apart..Being the mental midget that I am , I forgot how the cylinders go back on....The pistons are 2 different sizes..Does the larger diameter go to the front or back shoe ?? I would like to be able to drive this animal to the car shows this coming year , maybe ?? maybe another 7 years..Thanks...
charley hellickson
11-29-2006 23:34:25
 Re: Power Wagon wheel cylinders in reply to Roy Suomi, 11-27-2006 15:06:50
Hi Roy. Sorry I just found your post, I have been in the hospital for a few days. Stomach was hurting so bad I went to the ER Monday night and got home Wedsesday afternoon. ER Doctor said he had never seen anbodies belly with so much air in it. On those wheel cylinders, the large bore,cup, goes to the rear. I didn't know they were made with two sizes in one cylinder untill I looked it up. That is one Dodge I never worked on. Hope this helps. Good luck with it. Charley.
J G Hosafat
11-27-2006 16:48:48
The following shoe does most of the work so it woulds use the large piston.
So by that depending on where the cyl is located....
look at the wheel cyl and envision the expanding shoes in comparason to drum rotation....
so coming out of the wheel cyl. in a direction of drum rotation the small piston pushes against a shoe (leading shoe) through the adjuster through the next shoe (following shoe)and back to the second piston, into the cyl. whick would be the bigger one.
Also if applicable the following shoe might have a larger area of friction material.
Roy Suomi
11-27-2006 16:30:46
Hey Tim....Really ?? A hundred bucks ?? For a hundred bucks I'll let you sit in the seat and make all the motor noises you're heart desires..Just don't touch anything else ..O.K.???
LOL.. sorry , I had to bust yer hump..It's in the genes...
Tim Shultz
11-27-2006 17:12:30
 Re: Power Wagon wheel cylinders in reply to Roy Suomi, 11-27-2006 16:30:46
yeah, was just a joke.. if I bought I dodge though it would be a power wagone, but for now I"ll stick with my 73" F-250
and I would say even a rusted out power wagone would be worth AT LEAST $500, if not more.. Tim Shultz
floyd laughlin
11-27-2006 15:41:59
check with vintiaue power wagon fairfield iowa641 472 4665 he has it new or old he can tell you how
Tim Shultz
11-27-2006 15:21:43
aahhh.. if you don"t figger it out I will buy it for $100... as long as you pay the shiping.. lol
ok.. just kidding.. those are some of the best dodges made.. not that dodge has made very many good ones mind you, but thats one of the best.. a FORD lover, Tim Shultz
