Tractor Talk Discussion Forum
oliver tractor weights
bobby macdonald
11-27-2006 16:51:09
how heavy are rear oliver tractor weights ? 120 lbs , 130 lbs , 150 lbs , just want to see if i can find this out from anyone
HAPPY DEERE
11-27-2006 17:25:25
 Re: oliver tractor weights in reply to bobby macdonald, 11-27-2006 16:51:09
oliver rear wheel weights is a very broad range they made anything from 90#-150# for the 11 series and even bigger for the later ones. i do own a pair of four peice weights they are amaxing 50# each so much easier to install
Weldin Man
11-27-2006 17:06:33
Most oliver weights we have found are 130 Lbs. Cochshutt weights are very close to the same except the center hole is slightly smaller. we use bathroom scales to weigh them.
Dave Sherburne NY
11-28-2006 10:01:58
 Re: oliver tractor weights in reply to Weldin Man, 11-27-2006 17:06:33
Will those Cockshutt weights fit on an Oliver88??
SM in Wi
11-27-2006 17:00:07
I have a set from the 88 standard we had. 150 pounds each.
bobby macdonald
11-27-2006 17:02:16
 Re: oliver tractor weights in reply to SM in Wi, 11-27-2006 17:00:07
sounds more like it , feels more like it , just bought 6 of them for 200.00 , i know i got a good deal , atleast here in new england area , i can t find any front farmall weights cheap though ,
super99
11-27-2006 16:54:02
Not exactly sure, but I think they are closer to 90#. Chris
bobby macdonald
11-27-2006 16:58:04
 Re: oliver tractor weights in reply to super99, 11-27-2006 16:54:02
they are way over 100 lbs , i have 100 lb suitcase weights and they are heavier than that , i don t have a scale to see for myself , but they are more than 100 lbs each
