Tractor Talk Discussion Forum
Sealant for Gasoline
Red Dave
11-28-2006 06:04:03
I'm looking at sealing some threads that are in constant contact with gasoline.
What is a good thread sealant or gasket compound that gas won't disolve over time?
Mike M
11-29-2006 06:32:47
 Re: Sealant for Gasoline in reply to Red Dave, 11-28-2006 06:04:03
If this happens to be a fuel bowl ? I like permatex I think #1 the hardening type so you can get that fuel bowl lined up where it needs to be without overtightening it. The sealer will harden and hold it there if it is not as tight as you would like where you want it at. Other stuff I use the #2 non-hardening type.
Glen in TX
11-28-2006 21:41:51
One of the Permatex ones... Hi Tack
Gerald J.
11-28-2006 08:37:20
One or more of the vintage Permatex seals.
Sealall.
Rectorseal #5, also found in the plumbing department of home centers.
Gerald J.
souNdguy
11-28-2006 07:55:26
Check a plumbing store.. there is usually a yellow paste that is ok for gas/oil/lp gas/steam lines and mild acids.
soundguy
GregCO
11-28-2006 07:38:36
Here is another one that works good.
Greg
GregCO
11-28-2006 07:39:42
 Re: Sealant for Gasoline in reply to GregCO, 11-28-2006 07:38:36
I guess it would help if I actually put the link in.
Greg
Jay (ND)
11-28-2006 06:43:02
RectorSeal #5
john cub owner
11-28-2006 06:10:01
Check with your local auto parts store. they sell a gasoline resistant teflon tape. I believe it is yellow colored.
