Tractor Talk Discussion Forum
Case 611 carb problems
clayton mcnamar
11-28-2006 07:53:56
I have a nice case 611 but it won"t run on wide open. I have a feeling it"s not getting fuel on the high end. Low end or at idle, it runs and starts great! But when you open the throttle, it won"t run. I pulled the gas line and ran all new fuel line right from the tank. I cleaned the carb, and its fine too. Now i can"t get it to run wide open...?? My mind tells me something like dirt is in one of the jets, plugging the high end rev. but i JUST cleaned it! Can i get a carb kit for this tractor? YT doesn"t seem to sell one... help!?!?
Coloken
11-28-2006 13:13:57
 Re: Case 611 carb problems in reply to clayton mcnamara, 11-28-2006 07:53:56
If it runs OK at slow speed but not fast, It could be the float valve hole pluged or not opening enough. They make float valves with diferent size holes--could it have been changed?
vally farm
11-28-2006 08:50:00
Could you have put the carb back together wrong? My father has a 311B that had carb problems, I've rebuilt the fool thing at least 5 times, never got any better. The last time was tthis summer and it would dribble gas out the throat...first time for this. Finally had it re-built by the dealer, and the float had a pin hole...causing the dribble, but the upper casting had a slight warp, and THAT was what was causing all the other problems.Mike
junkfarmer
11-28-2006 08:23:06
You might not be getting enough voltage to the coil for the spark timing to keep up at higher rpms. Try checking the ignition system...points, condenser, dist. etc.
