Tractor Talk Discussion Forum
D-17 loader
Cindy Hutchinso
11-30-2006 07:48:12
Does anyone know if you can put a David Brown loader on a D-17?
JMS/MN
11-30-2006 08:29:29
 Re: D-17 loader in reply to Cindy Hutchinson, 11-30-2006 07:48:12
One consideration- if you're using the internal D17 hydraulics, the loader cylinders need to be able to handle about 3200psi. If you're adding an external system, match the pump and relief valve to the loader cylinders.
Rustyfarmall
11-30-2006 08:41:28
 Re: D-17 loader in reply to JMS/MN, 11-30-2006 08:29:29
I'd completely forgotten about the high pressure hydraulics on the Allis'. It does need to be taken into consideration.
Rustyfarmall
11-30-2006 08:00:48
That is a rather difficult question but it would not be impossible. You may have to make a few modifications to the loader, or locate the appropriate mounting brackets. On the other hand, it might just be a direct fit. Anything is possible if you have access to a cutting torch and a welder. In short, if you can get it mounted on the D-17, it will function.
