Tractor Talk Discussion Forum
hydraulic pressure
wayne from wi
12-04-2006 10:03:31
I have a couple hydraulic cylinders from a junked JD #45 loader laying around that I would like to use with my IH 966. It seems that I heard years ago that the hydraulic pressure of tractors later than mid 60's was too high to use these older cylinders on. Can anyone confirm this? Will I need to put a pressure regulator in the line to use them? Thanks
Bob
12-04-2006 10:11:05
 Re: hydraulic pressure in reply to wayne from wi, 12-04-2006 10:03:31
The old cast-iron Deere implement hydraulic cylinders used with the old two-cylinders won't take the pressure of modern hydraulics.
That is probably what you've heard about.
I don't know who could tell you for sure what pressure those loader cylinders can take.
Are they all steel, or do the have cast-iron "glands"?
wayne from wi
12-04-2006 10:39:16
 Re: hydraulic pressure in reply to Bob, 12-04-2006 10:11:05
Both ends are cast, and the cylinder/tube appears to be steel. I really don't have time to check with a magnet for a few days now. Thanks
