Tractor Talk Discussion Forum
Suggestions on rippers
Matt Page
12-05-2006 09:14:43
O.K. What I need is a D6 with rippers on the blade to drive around the pastures and root up old foundation blocks, pipes, and buried stumps. What I have is an old Oliver 130 hoss and a Case 110 hoss. It's pasture on top of an old sawmill townsite, and I'd like to renovate some pasture. Can't plow because of the trash, am looking for a large offset, but wouldn't it be best to have some sort of heavy ripper to drag around loosening the compaction and bringing up the trsh first? Matt.
John A.
12-05-2006 19:48:39
 Re: Suggestions on rippers in reply to Matt Page, 12-05-2006 09:14:43
Matt, I agree with Allan here. If you are in Brush Country ie...South Texas. The Dozer opperators have Root plows, on the rear oof their machines and Brush Rakes for the front, so the soil will silt on through and keep the bigger stuff, to pile up.
Check into it!! A good operator will run you about $100/hour on run time. If you get him to just Rootplow he ought to be able to do more than 5 acres/hour depending on density of trees and trash. If you let him pile it up too I will bet a "Big Red" sodawater he will ave 3acres/hour + - alittle. So that should put you in the $35/acre range!!! And that is CHEAP.
After that then start plowing and get the soil in shape for whatever you have in mind. Hope this helps.
Later,
John A.
marty G.
12-05-2006 17:40:00
In my opinion, you shouldn't dig too deep, if it's sawmill garbage underneath. I would go with a heavy offset or a heavy disk. I would stay on the surface, min-till style.
Allan In NE
12-05-2006 09:40:02
That's what we do out here when we yank out a tree row.
Hire a D8 cat with the 3 rippers. That insures that you get down deep enough to get all the stragglers.
Just my opinion,
Allan
Matt Page
12-05-2006 10:35:44
 Re: Suggestions on rippers in reply to Allan In NE, 12-05-2006 09:40:02
Well, the thing is its not just a fence row, its whole pastures that need it. That's why I was wondering about some kind of heavy something or other I could use on our own tractors and start working a pasture at a time. Just don't know enough about the things to know what I need... besides the dozer... ? matt.
Matt Page
12-05-2006 10:31:35
