Tractor Talk Discussion Forum
Ferguson tractor
Jim Shier
12-06-2006 08:45:36
I just bought a Ferguson tractor I am not sure what year or model it is but it has a gasoline tank with a screw on cap. starter is on the gear shift of course. I was wondering where the model or serial number plate or stamping is located on this tractor. it runs fine and has the small ninteen inch front tires. looks a little like a 9N Ford. I used to drive my uncles tractor like this one when I was a lot younger.
Jerry/MT
12-06-2006 09:48:14
 Re: Ferguson tractor in reply to Jim Shier, 12-06-2006 08:45:36
There should be a plate right above where the steering column comes through the dash with the serial number (TO XXXXX) stamped on it. When you find that, go to the Research & Info section on the left under serial numbers and look up the date. TO's up to TO60000 are TO-20's and TO 60001-TO 140000 are TO-30's. Then come to the Ferguson Forum when you have questions.
