Tractor Talk Discussion Forum
OT- 93 S-10 Blazer heater core question ..
mike in New Mex
12-07-2006 18:01:32
I have a Haynes book for this vehicle but it does not help much. Has anybody ever changed the heater core on a 93 S-10 Blazer? Does the whole dash got to be removed? If anybody has experience in this, please respond. Mike
mike in New Mexico
12-08-2006 08:31:20
 Re: OT- 93 S-10 Blazer heater core question .. in reply to mike in New Mexico, 12-07-2006 18:01:32
Well I got every thing unbolted under the dash but the ECM won't let the cover come out, and I can't seem to get the ECM out of the way ,
Any Ideas ??Thanks -mike
Bob
12-08-2006 09:33:38
 Re: OT- 93 S-10 Blazer heater core question .. in reply to mike in New Mexico, 12-08-2006 08:31:20
The ECM should either come down by removing a couple of screws, or maybe you have to depress a release tab, then slide the ECM out of a mount, then remove the mount.
Sometimes the darned things are held into the mount with double-sided foam tape, and you have to cut them loose, or tear them loose from the tape.
Ken Tallman
12-08-2006 08:07:23
I replaced a heater core in my 92 S10 blazer. I had to loosen the dash and slide it back a little bit to get the heater core out. It took me about 5 hours. Hardest part of the whole job is that there is not a lot of room. to work.
Ken
PeteNH
12-07-2006 19:39:53
I have a 1997 Blazer. I believe the 93 is similar. To change the heater cord I had to take the entire dash out. It took me about 6 hours working by myself. No hard to do just a lot to unbolt.
Bob
12-07-2006 19:51:37
 Re: OT- 93 S-10 Blazer heater core question .. in reply to PeteNH, 12-07-2006 19:39:53
1994 was the last year of the "boxy" mini-Blazer.
1995 and later are the new, rounded design.
I put a heat core in a 1994 several years ago (which SHOULD be very similar to the 1993), and while I don't remember the exact details, I can't recall it being too bad of a job, I certainly can't recall having to pull the whole dash. Of course, I could be suffering from CRS again!
Waljohn
12-08-2006 03:55:38
 Re: OT- 93 S-10 Blazer heater core question .. in reply to Bob, 12-07-2006 19:51:37
93 was the last year for the box. I have a 94 with the rounded design (217,000+ miles and going strong).
Bob
12-08-2006 06:55:59
 Re: OT- 93 S-10 Blazer heater core question .. in reply to Waljohn, 12-08-2006 03:55:38
Is your '94 a Blazer or a pickup?
It is my understanding the S-10 pickups got restyled in 1994, and the Blazers in 1995, unless it was a mid-year 1994 thing with the Blazers.
I have a 1994 babyblazer, an it is DEFINITELY the boxy, older style.
Waljohn
12-08-2006 12:11:57
 Re: OT- 93 S-10 Blazer heater core question .. in reply to Bob, 12-08-2006 06:55:59
I have the pickup. Did not know the blazer didn't change then, too.
bradk
12-07-2006 19:15:08
It's been a while since I did,but no,the dash doesn't have to come out.The bezel around the radio and the panel at rear of inside of glove-box has to come out.
The 2 worst things about the job is reconnecting the air tube and connector on top of the heater case and the top screws for the core cover.
3hrs to R&R.
Hope this helps.You can do it!
~brad
troy21
12-07-2006 18:18:06
i frogot what year my buddies is but we had to take the hole dash out.. it was a pain in the neck
old art
12-07-2006 18:18:01
go to auto zone or pepboys they have books you can read in the store may help
