Tractor Talk Discussion Forum
Case 580E hydralics problem
Bob Hill
12-09-2006 04:35:22
I was cleaning a ditch yesterday and the left swing cylinder on my backhoe started to feeling weak. It would work fine if not under any pressure. It is'nt leaking anywhere and all the other hydralics are working fine. Any suggestions. Thanks in advance.
135 Fan
12-09-2006 18:12:16
 Re: Case 580E hydralics problem in reply to Bob Hill, 12-09-2006 04:35:22
The seals on the piston could be leaking internally and wouldn't loose any fluid on the ground. Dave
AGRI-CON
12-09-2006 05:31:31
Is it the control lever or pedal feel weak? If so its not uncommon for the spring or hold down bolt to break in the control valve spool.
