Tractor Talk Discussion Forum
ot koler
sharp1
12-09-2006 19:38:48
I have a new koler engine on a john deere gator,It idles good but when you give it gas it boggs, only way to stop it is to run it with the choke out. thanks for any help
bo
12-09-2006 19:51:34
 Re: ot koler in reply to sharp1, 12-09-2006 19:38:48
Your carb needs cleaning....not maybe, but for sure. Any time you can run with choke out..you enrichen the mix so that more fuel gets in and the air is reduced...this is the same as if it was getting enough fuel, which it's not, with the choke in. So....you're not delivering fuel throught the high speed circuit of the carb....needs to come apart and be cleaned.
Ryan - WI
12-09-2006 19:46:26
Might be an airleak around the intake manifold. Spray some carb cleaner on both ends of the intake while it is running. If it speeds up, you have a vacuum leak.
