Tractor Talk Discussion Forum
OT 88 Chevy Suburban
Dave Sherburne
12-10-2006 15:10:38
Number 8 cylinder will not fire. It has spark,
and 115 lb. compression. It has throttle body fuel injection. Any Ideas??
bradk
12-10-2006 17:53:30
 Re: OT 88 Chevy Suburban in reply to Dave Sherburne NY, 12-10-2006 15:10:38
Vacuum leak from bad intake gasket or a sucked in intake valve.
Try spraying carb cleaner around the #8 runner and see if idle raises or miss goes away momentarily.
Pull valve cover off and remove both rockers for #8 cyl and look at the installed height of the valves.If one is higher(especially intake),it sucked in.~brad
Allan In NE
12-10-2006 15:18:19
Hi Dave,
Just a "for what it's worth", but all system vacumn is pulled from the number 8 cylinder rail.
Dunno, ya might wanna start in that area.
Allan
ErnieDD
12-10-2006 15:17:13
Exhaust valve not opening?
