Tractor Talk Discussion Forum
Question for Allen in Ne.
Nebraska Kirk
12-11-2006 16:26:02
Allen,
Will a Swartz wide front off of a Farmall 560 fit a Farmall M?
Jim J
12-11-2006 20:15:19
 Re: Question for Allen in Ne. in reply to Nebraska Kirk, 12-11-2006 16:26:02
The rear mount is the only part that is different. The mount is 2" shorter on the M. You can space it with washers make a spacer plate.
Steven@AZ
12-11-2006 17:36:39
Front end will fit, might need a different steering arm. The main bolster bolt pattern is the same for H thru 1456, steering arm pattern is different.
My Schwartz wide front came off a 450 and bolted right on to my H with zero modification to the main mount. Had to slot the holes in the steering arm so it would fit, though...
MN Scott
12-11-2006 17:06:53
Yes it will. The M tru 1456 all have the same mounting bolt pattern. The H, SH, 300, 350 have a differant bolt pattern but most swartz wide fronts are drilled with both bolt patterns.
Allan In NE
12-11-2006 16:37:40
Yeah, I think it will Kirk.
You're really gonna like that dude. Turns way shorter than the original IH did.
Allan
IaGary
12-11-2006 16:43:56
 Re: Question for Allen in Ne. in reply to Allan In NE, 12-11-2006 16:37:40
I hate to disagree with Allan but No it won't fit with out a torch and a welder.
The mount holes for the front mount are at a different level on 560 than a M.
Gary
Allan In NE
12-11-2006 17:08:56
 Re: Question for Allen in Ne. in reply to IaGary, 12-11-2006 16:43:56
Well, that's a bummer. Won't go, huh?
Are you talking about those four main mounting locations?
Allan
IaGary
12-11-2006 20:05:59
 Re: Question for Allen in Ne. in reply to Allan In NE, 12-11-2006 17:08:56
Yes I am talking the 4 bolts.
An IH front from a 560 would not fit on my MTA unless I would space down with a bushing or a bunch of washers.
The bolt pattern is right but the height is not.
Now maybe a schwart would fit because they are open in the front but I don't think so.
Gary
Allan In NE
12-12-2006 05:03:36
 Re: Question for Allen in Ne. in reply to IaGary, 12-11-2006 20:05:59
Yeah, I've ran into that issue too.
I used thick-walled pipe.
Allan
Delbert
12-11-2006 16:52:03
Not sure if they will fit but sure will make a nice tractor out that m.
