Tractor Talk Discussion Forum
briggs fuel pump help
chris sweetland
12-14-2006 13:53:31
Ok picture this me not paying attention to what i was doing pulled off the fuel and vacuum lines off the fuel pump now i have no clue how they go there is the port that comes out the bottom and the port that comes out the side thanks in advanced for the help Chris
Wayne Swenson
12-14-2006 17:40:38
 Re: briggs fuel pump help in reply to chris sweetland, 12-14-2006 13:53:31
Helps to know what model engine you are referring to.
That said, there should be 3 ports; 1 for gas in, 1 for gas out, & 1 for vacuum. Try blowing gently on each port; when you blow on the gas in port the air should exit the out port. The remaining opening should be vacuum. Suck on it to determine if it holds.
Kirk in PA
12-14-2006 18:05:59
 Re: briggs fuel pump help in reply to Wayne Swenson, 12-14-2006 17:40:38
I have no idea what happened here, but I'll repost the Huber story. The site seems unusually slow tonight.
