Tractor Talk Discussion Forum
OT Chevy 4 wheel drive question
georg
12-15-2006 19:18:42
Wanting to replace seal on right side of front drive housing on a 03 chevy 4WD 1/2 ton. What holds the inside gear on shaft?
Gear is loose but can't see any snap rings holding it on.
Thanks for your help.
traper
12-16-2006 05:24:52
 Re: OT Chevy 4 wheel drive question in reply to georg, 12-15-2006 19:18:42
All roads have crown oil runs to lowest point righside.
Allan In NE
12-16-2006 04:41:00
Yep,
Smack 'er with a big hammer.
How come they always seem to leak on the right side? Could never figure that one out.
Allan
bradk
12-16-2006 06:06:59
 Re: OT Chevy 4 wheel drive question in reply to Allan In NE, 12-16-2006 04:41:00
Allan,It's 'cause of the finish on the shaft. Remember they had a TSB which replced the shafts with a better machined sealing surface? The new ones are almost like a mirror. ~brad
Allan In NE
12-16-2006 06:19:08
 Re: OT Chevy 4 wheel drive question in reply to bradk, 12-16-2006 06:06:59
Hi Brad,
That must have happened after I left the wonderful world of GM. Last change I saw was the different, "new and improved" seal. :>)
Allan
bradk
12-15-2006 20:34:37
So you have the extension housing off?
If so,while holding housing in vertical position with CV joint flange down,hit the CV joint flange a good one with a hammer and it'll come apart.~brad
georg
12-16-2006 05:34:30
 Re: OT Chevy 4 wheel drive question in reply to bradk, 12-15-2006 20:34:37
You mean I could have replaced the seal with out having to take the housing off?
Thanks again
Allan In NE
12-16-2006 06:05:31
 Re: OT Chevy 4 wheel drive question in reply to georg, 12-16-2006 05:34:30
No,
You're on the right track because you can't get it back together again without the housing being off.
That darned wear washer drops down and there's no way to lift it to allow the axle to hit the hole with the housing still in place.
Best to do it on the bench like you're doing.
Allan
bradk
12-16-2006 06:01:05
No,You have to take it apart because the gear and washer will dislodge.And,you would never get the gear back on.It needs a little sweet talkin'.~brad
Bob
12-15-2006 19:28:50
There's an internal round-wire snap ring that lets go if you give the axle flange a quick yank (with a slidehammer, if necessary) much like pulling a CV shaft out of the transaxle on a FWD car.
