Tractor Talk Discussion Forum
prince hyd. pump rebuild?????
JD Ogden
12-15-2006 20:05:23
I have a prince hyd pump in need of some seals and bearings. Just wanted to know if anyone knows where to get rebuild kit thanks JD
JD Ogden
12-17-2006 19:23:44
 Re: prince hyd. pump rebuild????? in reply to JD Ogden, 12-15-2006 20:05:23
Thanks for the info.
J Schwiebert
12-16-2006 06:35:15
The rule most hydraulic distributors will tell you if the cost of the parts is 60% or more of a new pump buy the new pump. If you need bearings your center section is also worn.
NC Wayne
12-15-2006 21:17:51
Dalton Hydraulics is a full line Prince distributor. We've bought several things from them recently and they are a good bunch to do business with. As for rebuilding the pump just make sure the shaft isn't grooved where the seal rides. Typically by the time one gets to the age it needs a rebuild it is, and if so your just wasting time with it.
Gerald J.
12-15-2006 20:29:08
Force, Prince, maybe Baum Hydraulics.
Gerald J.
