Tractor Talk Discussion Forum
OT 1949 Studebaker pickup bed
JM in Merit
12-15-2006 21:17:00
Just got a 1949 Studebaker pickup trailer (pickup bed had been converted to a trailer).Going to make a fuel trailer out of it.
Trying to get the wheels off and one side I have twisted the bolts into trying to get the lug nuts off. So I took off the 8 bolts to try to take the hub off. But not sure what else I need to do the get the hub off so I can replaces the bolts for the lug nuts. I am sure I am missing something simple, but can not figure it out. The wheels are free they turn easy.
Any help greatly appreciated.
37 chief
12-16-2006 09:40:36
 Re: OT 1949 Studebaker pickup bed in reply to JM in Merit, 12-15-2006 21:17:00
The hub is probably on a tapered axel. You need to pound the axle to get the hub to pop off. there was a thread protector to protect the threads. It helps if you jack up the opposite wheel before hitting the axle. Since your wheel is off you can set the drum on a block. As others have said there are r&l threads. Stan
Don L C
12-16-2006 08:14:41
The end of the stud should be markef "L" if left handed.....
fred kobs
12-16-2006 04:10:33
What shape is the tailgate in?? I need a straight one! It does have L-hand threads on the one side. The hubs are pressed onto the axle on a 1/2 ton I know.
dan hil
12-16-2006 01:08:13
you may have left hand threads on one side.
