Tractor Talk Discussion Forum
Hey Allan - plow question
Paul in On
12-18-2006 06:33:11
Allan,
Wanted to know what u sprayed onto your plows to keep them rist free and shiney. Remembered you had a pic up of your plow and you could see the reflection like you were looking into a mirror. What's your trick? Paul
old art
12-18-2006 13:22:41
 Re: Hey Allan - plow question in reply to Paul in On, 12-18-2006 06:33:11
my dad made shure his shovels were all shinney as that plow and if i used it. it better be clean and oiled when it was put away. they work easer and better. wish he was here to get on my case now
c hess
12-18-2006 08:44:27
Use a spray can of clear coat an you will feel good every time you walk past it on those cold winter days !!!!
Allan In NE
12-18-2006 06:57:25
Hi Paul,
Just about anything will work that will keep the moisture and oxygen away from the metal.
Cheapest way I've found is to just get a couple of cans of aluminum or flat black spray paint from your local hardware or tractor supply store.
Allan
third party image
Paul in On
12-18-2006 07:25:33
 Re: Hey Allan - plow question in reply to Allan In NE, 12-18-2006 06:57:25
You apply after ur done plowing for the season, then in the spring you just go out and dig in?
Allan In NE
12-18-2006 08:10:53
 Re: Hey Allan - plow question in reply to Paul in On, 12-18-2006 07:25:33
Yes Sir,
It will pull that coat off the shares within 20 feet.
Allan
Paul in On
12-18-2006 09:35:22
 Re: Hey Allan - plow question in reply to Allan In NE, 12-18-2006 08:10:53
Thanks for your help sir! Appreciate it. Have a good one. Paul
Peabo
12-18-2006 07:03:06
If ya don't do anything does that thin layer of surface rust really hurt anything?
Peabo
Brian in MO
12-18-2006 07:18:24
 Re: Hey Allan - plow question in reply to Peabo, 12-18-2006 07:03:06
Peabo the simple answer is yes. A Plow works at it's best when it looks like Alan's, most people are only plowing a small amount and don't even get them cleaned good before they are done. To do the best job (Alike for a garden) they need to start out clean. Also that "thin" layer of rust quickly becomes a thick layer when the plow has sat for a year or two longer than you thought it was going to. Brian
Peabo
12-18-2006 09:55:50
 Re: Hey Allan - plow question in reply to Brian in MO, 12-18-2006 07:18:24
Thanks to you and Allan, Very informative, I had never really thought about it!!
RustyFarmall
12-18-2006 08:07:39
A few years ago I bought a Case pull type plow at auction. It had sat outside for many years since it was last used, and appeared to be rusted beyond hope, but when I got it home I went at it with a wire cup brush on an angle grinder and almost immediately I was pretty well covered with grease splatters. What I thought was rust turned out to be dirty grease. Someone had taken the time to do it right after the last use, and those plow bottoms cleaned up very well. I sold the plow a few weeks later for a good profit.
Allan In NE
12-18-2006 07:10:15
Not if ya keep the plow busy. :>)
This old plow is worn out and needs a lot of new iron. I didn't even coat it this fall since I have to rebuild the darned thing before another season anyway.
Wanted to find a good Massey to take it's place, but they are kinda hard to find anymore, so looks like I get to turn 'bout a million bolts prior to this spring's work. :>(
Allan
Wisconsin Cowman
12-18-2006 06:38:59
I use grease and used motor oil and apply it with an old paint brush.
