Tractor Talk Discussion Forum
Diesel fuel additives
Doug Downey
12-18-2006 08:03:22
Are the diesel fuel additives really worth using. Also do they go bad after a couple years (I've had some setting on a shelf for a couple years, wonder if I can use it)? Thank you in advance. Doug
Doug Downey
12-19-2006 15:36:24
 Re: Diesel fuel additives in reply to Doug Downey, 12-18-2006 08:03:22
Hello, I bought some of the Power Service Diesel Kleen and Cetane Boost is this the stuff I need Thanks in advance, Doug
mj
12-18-2006 13:19:47
third party image
Here's a bit more about the ULSD fuel and its' effects on current and older diesels.
Jerry/MT
12-18-2006 12:57:58
The low sulfur fuels are supposed to have an additive package to alleviate lubricity problems. The lack of lubricity that occurs in low sulfur fuels is not due to the lack of sulfur but is due to the process that removes the sulfur.
Doug Downey
12-18-2006 09:42:30
Thank you all for your replies. This is a great forum site!!!!! Thanks guys
Stumpalump
12-18-2006 08:34:19
Lucas fuel treatment. Buy it by the gallon at truck stops. Low Sulfer fuel is low lubrication fuel and Lucas adds lubrication back to the fuel.
Injector pump will be happy and you can feel it run smother on long pulls. It works great in my 98 chevy 1 ton so I put it in everthing but the company car.
mj
12-18-2006 08:33:24
They should have a pretty long shelf-life; you could check with the distributor or manufacturer and find out. I pretty much stick with Power Service for the anti -gel and lubricity properties but there are lots of good brands out there. The new Ultra Low Sulphur Diesel that became the on-road standard in October may behoove owners of older diesel cars and trucks to add conditioner to prevent premature wear to the injection system. I always add PS in my diesels with every fill up just in case the bulk plant gets skimpy on their additives; I consider it cheap insurance.
JT
12-18-2006 08:14:28
Depends on what brand. I use either Howe's brand of additve or Power Serve. I use them as an anti-gel. Have used some of the Cetane booster, did not any differance.
