Tractor Talk Discussion Forum
Re: 1953 ford NAA
NO NO NO!
12-18-2006 11:16:11
DO NOT connect a 12 volt battery to a 6 volt battery unless you'd like it to blow up in your face!
Better way (and way more safer too)is to hook jumper cable direct to the starter on the disabled tractor, with ignition on. MAKE SURE TRANSMISSION IS IN NEUTRAL FIRST!!!! So it doesnt drive over you when it starts!
The starter doesnt care if it is 6 volts or 12, the rest of the electrical system is not quite so forgiving.
jubilee johnny
12-18-2006 12:58:49
 Re: 1953 ford NAA in reply to NO NO NO!, 12-18-2006 11:16:11
I guess we are opening a can of worms. It would be best not to use a 12v at all and an NAA has a safety switch that will NOT allow it to start in anything BUT neutral. Sorry for the commotion.
RustyFarmall
12-18-2006 11:24:53
You are 100% correct. Even if jumping with another 6 volt battery, it is safer to do it that way.
