Tractor Talk Discussion Forum
HELP!! 8N Lower Link Support Pin
Stump Jumper
12-22-2006 18:38:41
I had to replace the outside nut but it spins before I can get it tight. How is this accomplished? Do I need to get inside to hold the other end? Thanks for your help
old
12-22-2006 19:05:53
 Re: HELP!! 8N Lower Link Support Pin in reply to Stump Jumper, 12-22-2006 18:38:41
If it spins that way then you have other problems also. That pin has a taper fit to the rear end and should be tight and if it isn't then it will leak fluid and also can hurt the trumpet and even destory it over time. To fix that you have to pull off the trumpet and if it where me I would replace the pin and tighten it up as it should be.
Stump Jumper
12-23-2006 15:58:32
 Re: HELP!! 8N Lower Link Support Pin in reply to old, 12-22-2006 19:05:53
Thanks for the info. Not exactly what I wanted to hear. but..... .. I will replace it this winter when it finally gets cold and I get time. Merry Christmas :)
